Changing Printing Speed on MK4S with MMU3
Nodak7
(@nodak7)
Help! OK obviously I am missing something here. I am trying to print some items that have over hangs. One recommendation was to reduce the print speed. Seemed like a good, simple and straightforward suggestion. Once the print has started I go to menu on the printer screen select "Tune" then select "Print Speed". When I change it from 100% to 60%  it does slow it down. Unfortunately when the printer changes filaments it returns to 100%. I tried changing it on each filament but it just returns to return to 100% after each filament change. How can I stop that change? Am I missing something else I need to do?
Veröffentlicht : 20/07/2025 8:17 pm
BaconFase
(@baconfase)
RE: Changing Printing Speed on MK4S with MMU3
Speeds and temps are more or less reset on every filament(MMU)/tool(XL) change so tuning these options at the machine during a print is temporary at best with no way around it outside of babysitting your printer at every single change.
If you need to slow overhangs down by 40% to get a successful print then you should edit those parameters in the slicer, reslice, and redo the print.
Veröffentlicht : 22/07/2025 3:42 am
Nodak7
(@nodak7)
Thanks for the reply Bacon! Seems to be the case. Where in the Slicer do I find the speed setting? When I go under the "Print Settings" tab I see no Print speed setting per se. Lots of other settings I am not familiar with!
Veröffentlicht : 22/07/2025 11:11 am
BaconFase
(@baconfase)
The slicer doesn't have an "overall print speed setting percentage" like what the lcd knob does. Instead, all the different features' speed settings are enumerated out in Print Settings>Speed and this block of parameters is for overhangs:
Veröffentlicht : 24/07/2025 7:17 am
Nodak7
(@nodak7)
Thanks again Bacon! I know that in the slicer these settings can be changed for each individual filament. I guess I will have to play around a bit to find the optimal setting. Nothings straightforward. LOL
Veröffentlicht : 24/07/2025 11:34 am
