Changing layer speeds
Simon B
(@simon-b)
Hi - Apologies if this isn't the correct area to post this, and please move if required.
I am very new to Prusa and 3D printing and would like some help if that's ok. I have an Elegoo Neptune 2s if that's of any help. The part I am printing is "curling" up on the corners, which is mainly due to the abrupt change in section size, which unfortunately cannot be changed (see attachement). I have reduced the speed of the first layer and added a 10mm wide, 0mm offset brim which has greatly reduced the "curling" . I am using eSun PLA+ filament which is producing excellent results throughout the rest of the model.
Is there a facility in Prusa where a range of layers ie 0-100 can be printed at slower speeds than the remainder, in an attempt to reduce the "curling"?
I have browsed through the Prusa settings and as a beginner, it's a bit of a minefield, so any help would be great.
Many thanks
Posted : 09/02/2023 2:48 pm
Import your part, right click on it and select 'Add modifier', select one and adjust to cover the desired volume, then right click on the modifier and select 'Add settings > Speed'
- tick the extrusions you wish to modify and click OK
You can now enter new values for that modifier in the pane on the right.
Posted : 09/02/2023 3:01 pm
Simon B
(@simon-b)
RE: Changing layer speeds
Hi Diem - thanks very much for you fast reply, much appreciated. I have followed your clear instructions and see I have a range of elements I can select to change the speeds etc, but I'm unsure which elements to select. In my picture in my post, would the "stepped" feature be a perimeter, small perimeter etc? Is there a way to interrogate the model in the slicer to identify what the elements are and hence what I should change?
Many thanks
Posted : 09/02/2023 3:19 pm
Simon B
(@simon-b)
Hi - just to add to my post for clarity, the picture shows the layers I would like to print at slower speeds to try and stop the "curling" on the corners. The layers appear to be a mixture of solids and infill as you'd expect, but I'm unsure how to go about adjusting the layer speeds for each type of element etc.
Many thanks
Posted : 09/02/2023 4:19 pm
Do a trial slice.
You should see a features list in the top corner - if not press 'L' - it is colour coded.
Use the slider to look through the model and cross check the colour of any extrusion you want to change against the chart...
Posted : 10/02/2023 5:07 pm
Simon B
(@simon-b)
Many thanks for that and I think I have it sorted thanks to your much appreciated help. I think the issue with my print was the abrupt change of section size ie thick to thin, which as we know is a "no go" if casting or moulding something similar. The print is for someone else so I cannot really change the design. I modelled it in FreeCad. I printed a portion of the item last night and the corners have stayed flat, so being able to adjust the properties, seems to have worked. Thanks for your help again. 👍
This post was modified 3 years ago by Simon B
Posted : 10/02/2023 5:58 pm
