Can't add new model in Printables
gfretz
(@gfretz)
I am trying to add a new model to my collection. I clicked "Create" and it took me to the new model site. I filled in the information, added pix and the model STL file and then clicked "save draft". Nothing appeared to happen. When I went to "My Models" page, the new model appeared as a "draft". However, when I open the draft, it is missing the title, the summary, the description etc. It does show the pix and the model file. There is no edit button that I can find and I can't get back to the new model site. Is this a known issue or am I missing something?
G
Postato : 15/04/2022 7:56 pm
Matt Boyer
(@matt-boyer)
RE: Can't add new model in Printables
After you save the draft you slide the bar to PUBLISH, and publish it.
Postato : 16/04/2022 11:36 pm
gfretz
(@gfretz)
Thanks for your response, Matt.
I have saved a draft which appears on my homepage (see below)
When I click on this draft, this is what comes up:
This looks like a preview page, however, the title, summary and description are missing. The photos and STL file do show.
I can't figure out how to get back to the create page to edit or to use the "Publish" button.
I thought it might be the browser (Brave) but it doesn't work in Safari either.
G
Postato : 17/04/2022 3:26 am
Peter H
(@peter-h)
It looks as though you've lost your text somehow - that happens occasionally to me - usually if I wander off and do something else without "saving" the document - the images save because you've uploaded them, but the text sits on your machine until you actually hit a button (I think).
To open the page for editing - just click on the three little dots to the right (a compressed "hamburger" menu) and you should be good to go.
Postato : 17/04/2022 11:56 pm
Peter H
(@peter-h)
I forgot to mention that the "hamburger" dots are also on the top right of your thumbnail images - you can do directly to edit mode from there if you wish.
You have saved two drafts of the same  document - but since neither are named you probably don't have your text saved in either.
All the best!
P
Postato : 18/04/2022 12:12 am
gfretz
(@gfretz)
Thanks Peter. I discovered the problem. I had not completed the license information and there was an extra space at the end of the STL file name. Once these corrections were made, I was able to publish it.
G
Postato : 18/04/2022 2:46 am
1 persone hanno apprezzato
Juan151
(@juan151)
However, there was a bit of confusion among users about whether they are “allowed” to use PrusaPrinters when they don’t have one of our 3D printers. So we started looking for a new name.
Postato : 21/04/2022 9:25 am
