Can anyone tell me the name/source of the power panic connector?
Sean Roach
(@sean-roach)
I'm tired of messing with my printer in the very tight confines of my lack v2 enclosure. I'm also annoyed at having to fish the power cables through the hole in the table.
I'm about to rig up a terminal block, inside the enclosure, to make removal of the printer easier, but that leaves the Power Panic cable.
Can anyone tell me where I can find, or at least the name, of the connector used for the Power Panic cable? I'm wanting to run a short extension, so I'll need to source both male and female ends. I'm wanting to use the exact same connector, if possible, as it means I won't have to splice into the original.
Postato : 07/12/2022 3:53 am
René
(@rene-3)
RE: Can anyone tell me the name/source of the power panic connector?
That is a Molex Micro-Fit connector I believe.
Postato : 07/12/2022 8:30 am
Sean Roach hanno apprezzato
René
(@rene-3)
See also https://www.molex.com/molex/products/family/sl_connectors?parentKey=wire_to_board_connectors
Postato : 07/12/2022 9:17 am
Sean Roach
(@sean-roach)
Thank you. Two cables, (one each male-male and female-female), ordered. This should make working on the printer MUCH easier.
Postato : 07/12/2022 11:32 pm
