Brass nozzle wear
REIFY 3D
(@reify-3d-2)
Brass nozzle wear
Assuming that non-abrasive materials i.e. PLA/PETG are primarily used, what is the mean time/length before nozzle changes?
Napsal : 16/02/2021 10:02 am
Thejiral
(@thejiral)
RE: Brass nozzle wear
That also depends on the "non-abrasive" material you are using. Even different colours of the same material can show different levels of abrasiveness. From what I know many white filaments for example tend to substantially more abrasive than others (less than metal infill etc however). I would also assume that it also depends if you have a high quality or a cheap brass nozzle. The former might be the same material as the latter but often has greater margins for degradation where it still prints fine.
Napsal : 16/02/2021 12:50 pm
Posted by: @brisance
I change after about 3000 hours - but different filaments wear the nozzle at different rates.
Napsal : 16/02/2021 4:34 pm
Steve
(@steve-3)
I am on my 6th nozzle after 7450m of filament and 178d 19h, printing nothing but PLA. Some of them were changed because of a clog instead of nozzle wear.
They are considered to be consumable and generic nozzles are really cheap.
Steve
Napsal : 16/02/2021 11:09 pm
@steve-16
Just be aware that some generic nozzles have short threads and do not seat properly.
Napsal : 16/02/2021 11:41 pm
Steve
(@steve-3)
Posted by: @diem
@steve-16
Thanks for the heads up. I have been lucky so far with a set of 15 for around US$10 from Amazon.
Napsal : 17/02/2021 1:09 am
Just be aware that many of the cheaper nozzles use substandard brass. I've seen a few pics taken that show them shearing off easily after printing with higher temps. They are also often not cut to E3D specs, so print quality may suffer. The following pic from TriangleLab (a good quality clone nozzle) shows the difference in the collar around the nozzle opening (the B dimension in the E3D drawing).
The surrounding area should be about 2X the nozzle opening size to give good squish and adhesion with underlying layers, particularly if you use wider extrusions.
Napsal : 17/02/2021 6:56 pm
