Article: Calibrating Filament for Functional Prints
I've gathered all my notes on calibrating filament in a Printable article: Calibrating Filament for Functional Prints
Please let me know if there is anything that is: wrong, not clear or can be added
And yes, the cover image was AI generated so it's a bit wonky.
Napsal : 27/02/2026 9:07 pm
3 lidem se líbí
Robin_13
(@robin_13)
RE: Article: Calibrating Filament for Functional Prints
Thank you for including the links.  Following your procedure should ensure that your prints are very close to design specifications.
My procedure is very close to yours.  I just learned a couple of things from your procedure that I may add to mine.
For my vase mode, I designed an octagon shape to measure angled printing as well.  I have noticed that is does make a difference.  As a side note, my little octagon shape is a nice size for mixing up small amounts of epoxy.
For filaments that I am going to do large prints with, I do a large calibration test.  Full print plate for X/Y cross and a full Z height tower.  It can make a difference.
Napsal : 28/02/2026 5:29 am
