Annealing temperature PC Blend
hawai
(@hawai)
Hi there,
following up on another thread were @Diem strongly recommended annealing as a potential fix for warped flat prints I tried to find the glass transition temperature for the PC Blend. Failure all around!
Most freely available info I could get was about PLA, ASA/ABS and PETG based materials. Anybody aware of a good source for this type of information or even better could let me know what annealing temperature would be a good starting point for the PC Blend?
Cheers
Hansjoerg
Napsal : 27/08/2021 12:18 am
Swiss_Cheese
(@swiss_cheese)
@hawai
look you people are blowing my mind, anything above 114C move on.
BTW hawai I like you
enjoy
Swiss_Cheese
The Filament Whisperer
Napsal : 27/08/2021 1:07 am
hawai
(@hawai)
Merci vielmal
Thanks Mr.Cheese!
So off to the kitchen oven it will be. I will report back once the deed is done!
Napsal : 27/08/2021 1:32 am
hawai
(@hawai)
It worked!
Layered between two Pizza stones (the only flat and heat resistant things that I had available), weighted down with two kgs, heated up to 120 degrees, left it there for an hour, turned the oven off and let it cool down.
Nice and flat!
Two more rounds to go and I can finally assemble the project 🙂
Napsal : 27/08/2021 6:39 am
1 lidem se líbí
