Additional Printer Profiles for PrusaSlicer
Hello,
I am looking for a printer profile for the Creality CR-10 S5.
Has anyone finished something yet?
RE: Additional Printer Profiles for PrusaSlicer
I've got one for my cr10s, however Ive made it direct drive so the retract settings are set to 0.8mm same as my mk3.
All you would need to do is modify the physical print area to match your S5 and increase the retraction to whatever you use currently.
Ive (tried) to attach the ini file which was actually generated by PrusaSlicer 2.0 but there seems to be an issue with 2.0 at the moment where it wont import its own configs but will from earlier versions due to the header string so I've already replaced the header with one from the beta release. So 2.0 should import the config. Assuming Ive figured out how to attach files to the nw forum posts 🙂 Wouldnt let me attach an ini file so ive changed the type to txt. you will have to rename.
Thanks. That would help a lot.
If I were you, I would ask in CR-10 facebook group.
I don't have Facebook anymore and I won't register again.
So I don't have that option.
