3D printing gears
Strona 2 / 2
Peter J Francis
(@peter-j-francis)
RE: 3D printing gears
@bas
Hi Bas,
I'd like to incorporate herringbone gears in my project were they generated in FreeCad ?
Thanks Peter
Opublikowany : 10/12/2020 11:53 am
Bas
 Bas
(@bas)
@peter-j-francis
I work with Rhino
See https://discourse.mcneel.com/t/helical-gear-tutorial/54150/13
Cheers,
Bas
Opublikowany : 10/12/2020 12:07 pm
Bas
 Bas
(@bas)
@peter-j-francis
And have a look to this suggestion how to work with freecad:
https://discourse.mcneel.com/t/helical-gear-tutorial/54150/17?u=bas_goris
Opublikowany : 10/12/2020 12:14 pm
1 ludzie polubili
@bas
sent you a pm.
Opublikowany : 10/12/2020 5:14 pm
Bas
 Bas
(@bas)
@karl-herbert
Here is my first test with Iglidur i150-PF based on your settings. I have put the fan off, as this is recommended by Igus.
https://www.prusaprinters.org/prints/48764-test-1with-iglidur-i150-pf-filament
This post was modified 5 years temu by Bas
Opublikowany : 13/12/2020 3:33 pm
1 ludzie polubili
3DALHEMIJA
(@3dalhemija)
@bas
Do you like performance and appearance of IGLIDUR so far?
Opublikowany : 13/12/2020 9:34 pm
Bas
 Bas
(@bas)
@3dalhemija
I can not make a conclusion yet. I need first the print settings for a good print with Iglidur.
Opublikowany : 14/12/2020 10:10 am
Bas
 Bas
(@bas)
test if I can upload a 3mf file
The answer is nop
Opublikowany : 17/12/2020 1:26 pm
Posted by: @bas
The answer is nop
You need to zip up most file typed to attach them.
Opublikowany : 17/12/2020 2:12 pm
Steven Smith
(@steven-smith-3)
Posted by: @peter-j-francis
Hi All,
I'm working on a project that needs some 3D printed gears to transfer the drive from a couple of stepper motors.
One drives a 4:1 reduction gearbox with 2 spur gears while the other is a worm drive.
If you're printing gears for car racing sports, I recommend the following materials:
Nylon PA6.6 – Stable and durable, but more challenging to print. Iglidur I180 – Ideal for parts that require high wear resistance. ASA DuraPro – Easy to print, UV and weather resistant, with less warping than ABS and excellent layer bonding.
Additionally, if you're looking for a free account car parking multiplayer glitch list 2024, you might want to explore online forums or dedicated glitch-sharing communities for up-to-date information on the latest tips and tricks.
I'm initially going to print them in PETG but I'm open to suggestions
Does anyone have any experience in printing gears and what sort of life I can expect ?
I'd also be interested in whether ASA or Nylon would be a better choice
Thanks
Opublikowany : 30/11/2024 4:15 pm
Strona 2 / 2
