3D Printer Life Expectancy
Seite 1 / 2
Mitglied
How long can we expect a printer to print?
Veröffentlicht : 10/05/2021 5:02 pm
Mitglied
RE: 3D Printer Life Expectancy
I found this article:
https://3dprinterly.com/how-long-does-a-3d-printer-last-creality-ender-3-others/
Veröffentlicht : 10/05/2021 5:03 pm
Larry Tener
(@larry-tener)
Until it quits, depending on how you care for it. I'm into year 3 on my MK 3 and going strong, but then i have kept warn parts replaced and done preventive maintenance.
L.
Veröffentlicht : 10/05/2021 5:06 pm
Mitglied
@larry-tener
I am in a similar bet.  MK3S x 3 years.  Ender 3 never worked.
Veröffentlicht : 10/05/2021 5:14 pm
Larry Tener
(@larry-tener)
Yea, I’ve kept my original MK3 updated till is a S model with some + updates and a Mosquito hotend and changed out anything I thought needed repaired as I went along. It’s a “lights out machine” as far as I’m concerned, just make sure it’s got a good start and walk away. I’m somewhat picky about filament and buy nothing that isn’t 0.003 tolerance or better. I also have a Mini that is the same way since I installed a Mosquito on it. I and a friend have 4 Prusa machines between us and they all have been changed to Mosquito hotends and work great.
L.
Veröffentlicht : 10/05/2021 5:43 pm
Mitglied
@larry-tener
Do you use the standard or high temperature thermistor?
Veröffentlicht : 10/05/2021 6:50 pm
Larry Tener
(@larry-tener)
I used the standard, the one out of the original hotend, same for the heater.
L.
Veröffentlicht : 10/05/2021 7:09 pm
Mitglied
@larry-tener
I have two with the high temp.  I also have Bondtech on them so I wait for their firmware,
Veröffentlicht : 10/05/2021 7:10 pm
Larry Tener
(@larry-tener)
I have run ASA in it without any trouble.
L.
Veröffentlicht : 10/05/2021 9:51 pm
Mitglied
@larry-tener
As have I am many others.
Veröffentlicht : 11/05/2021 2:01 am
Larry Tener
(@larry-tener)
I don’t have a need for anything higher temp than that at this time.
L.
Veröffentlicht : 11/05/2021 2:20 am
Mitglied
@larry-tener
That is a good way to start but for me, I sometimes need higher temperatures.
Veröffentlicht : 11/05/2021 2:22 am
Gonper
(@gonper)
Posted by: @cwbullet
First of all we can not say something like 3 years. It will be something like 10,000 working hours. If the machine only works 10 h/week will last almost forever... but if the machine works 10h/day may lasts only a couple of years.
Anyway even answering on Work Hours the answer is "Depends", mainly on maintenance, and how much we want to spend on that.
Every wearing component has different expectancy working life, and they can be replaced when they fail or just before a fail ocurrus. Most componentes, are small, cheap and easy replaceable (Motors, bearings, nozzles, cables, power supply, etc.)
Let's say that probably the most expensive component is the main mother board. After a time it will fail, and will need to be replaced. Provably this is the point to think about replacing the full machine (Sometimes not) because probably more advanced boards and chassis will have arrived to the market and our printing will benefit with such innovations more than upgrading the old machine.
Veröffentlicht : 11/05/2021 7:38 am
Mitglied
I guess the answer is indefinitely as long as you do maintenance.
Veröffentlicht : 11/05/2021 10:21 am
StanHD
(@stanhd)
Yes agreed.  In the UK (and perhaps elsewhere) we may refer to the term "Triggers Broom". Alternatively  and far more highbrow the "Ship of Theseus".
In other words "I've had this printer 10 years now, replaced every part twice and it's still going strong."
Veröffentlicht : 11/05/2021 10:50 am
jsw
 jsw
(@jsw)
My guess is that they will be mechanically viable (unless you abuse them) long after they are functionally obsolete.  Kind of like digital cameras.  A ca. 2000 5 mp camera is obsolete by today's standards, but I have one of them of that generation that still works quite well.
Veröffentlicht : 11/05/2021 12:08 pm
Mitglied
@jsw
You are probably right.  obsolete before they stop working.
Veröffentlicht : 11/05/2021 12:44 pm
It's like a B-52. Taken care of, they'll last forever, but you're going to replace some parts.
Veröffentlicht : 11/05/2021 1:23 pm
Mitglied
@bobstro
I hope so.  I hope Prusa maintains the upgrade paths.
Veröffentlicht : 11/05/2021 2:39 pm
Swiss_Cheese
(@swiss_cheese)
I've read this entire post, and I still don't know how long does it takes to get to the tootsie roll center of a tootsie pop. 😛
The Filament Whisperer
Veröffentlicht : 13/05/2021 3:06 am
Seite 1 / 2
