2 kg prusament spool dimension
IanY
 IanY
(@iany)
Does anyone know what the dimensions of a 2 kg prusament filament spool - width, outer diameter and inner hole diameter
I have an eSUN eBOX Lite Filament Dryer and want to know if the 2 kg spool will fit in it.
Ian
Publié : 13/09/2023 10:02 pm
Artur5
(@artur5)
RE: 2 kg prusament spool dimension
I don’t know the exact figures but, judging by the photos on Prusa’s eshop, 2Kg spools seem to be nearly twice in height and about the same in diameter, if compared to regular 1Kg spools,
My filament drier is a similar Esun model, able to take different brands of  1 Kg spools without problem, but there’s little spare room left on the sides. No way a 2Kg spool of Prusament would fit in there.
Publié : 15/09/2023 9:13 am
IanY
 IanY
(@iany)
From the comments and adjustments regarding a better fit in this posting.  It sounds like it is around 125mm wide.
https://www.printables.com/model/461663-spool-holder-1kg-or-2kg-for-original-prusa-enclosu/comments
Publié : 15/09/2023 11:42 am
IanY
 IanY
(@iany)
A designer of a 2kg spool holder replied with the dimensions - width 123mm, outer diameter 200mm, inner hole diameter 52mm.
Publié : 15/09/2023 3:20 pm
The two extremes of 2kg spool:
Prusament -    Outer Diameter: 200    Inner diameter: 51    Width: 123
Filamentum PM -    Outer diameter: 298    Inner diameter: 53     Width: 100
Measured with ancient, school ruler...
Publié : 15/09/2023 3:42 pm
Artur5
(@artur5)
According to Esun specs for the eBox lite drier, the max. spool size is 200mm, outer diameter and 73mm. width. This drier is designed with 1Kg spools in mind. For 2Kg you'll have to look elsewhere.
Publié : 16/09/2023 7:26 am
Hello
(@hello)
Posted by: @iany
Ian
No it won't fit in the box I have the same box
Publié : 16/09/2023 10:26 am
Clemens M.
(@clemens-m)
These spools have the same diameter than the 1kg spools, also inner diameter of the spool is the same, they create the volume vor the 2kg of material by the length of the cylinder of the spool. I once had an original spool of Prusament - but I don't know the width of the spool.
Best regards, Clemens
Publié : 16/09/2023 10:44 am
