Voronoi-Teddybear
Knickohr
(@knickohr)
Utenti Moderator
Voronoi-Teddybear
I printed this voronoi complete without supports. Looks good, not perfect, but OK.
Printtime 50h, uses 115m of filament 😯 I use rigid.ink PLA Plus+. Fills nearly complete volume of the printerspace (23x19x20cm)
Any suggestions for smoothing PLA ?
Thomas
Postato : 23/03/2017 3:31 pm
logan.b
(@logan-b)
Re: Voronoi-Teddybear
Hey Thomas!
Great looking print! So far I have found two successful ways to smooth non-ABS prints: 1.)Bondo putty, sanding, and priming (several coats), and 2.) Two-part epoxy casting resin. I would recommend the two-part epoxy resin because I feel that it takes a lot less manual labor to get pretty awesome results.
One of the most commonly recommended resins is XTC-3D by Smooth-On ( https://www.smooth-on.com/products/xtc-3d/ ). Personally, I have used XTC-3D and Easycast and I have found that they are pretty comparable... I would say pick the stuff you can find at Hobby Lobby, Michael's, etc. and save yourself the cost of shipping!
Thanks,
Logan
Postato : 21/04/2017 12:46 am
