Smoking flaming dumpster fire
jsw
 jsw
(@jsw)
For the industrial area on the model railroad.  Generic dumpster print downloaded from one of the 'usual suspect' sites and upscaled to approximate O scale.
Internal electronics are two 'flickering' LEDs, red and yellow, and a 10 ohm power resistor for the smoke unit.  Uses the common MegaSteam smoke fluid.  The flickering LEDs do simulate a roaring flame, but I'm too lazy to do a video.  😉
My attempt at making the power plant smoke resulted in a lot of stink and little visible smoke (I am still working on this) but this one SMOKES!
Opublikowany : 09/02/2021 12:16 am
3 ludzie polubili
RE: Smoking flaming dumpster fire
Pretty cool.  Don't catch it on fire.  In college, we used to do that with couches, but that is another story.
Opublikowany : 09/02/2021 1:14 am
jsw
 jsw
(@jsw)
Posted by: @cwbullet
Thanks.
Don't worry.  That thing is going to be on only for about a minute at a time.  It produces smoke fairly quickly.  For the above photo I was running it on a bench supply, about 20VDC and I shot the photo maybe 15 seconds after powering it up.  When it's set up on the layout, I plan on running it on the 20VAC accessory voltage from a Lionel KW transformer, so it should start smoking within 10 seconds or so.
In reference to a comment from 'another network', no, it does not set off the smoke detector.
And, in reference to a previous thread, I just printed a 364c control switch for it in a very appropriate color.  😉
Opublikowany : 09/02/2021 2:03 am
1 ludzie polubili
Gonper
(@gonper)
Very cool, does the leds flicker like real flames?
Opublikowany : 09/02/2021 10:38 am
jsw
 jsw
(@jsw)
Posted by: @gonper
Yes, they do.  There are red and yellow flickering LEDs that flicker asynchronously and look remarkably real.
They come from a 'maker' site called Evil Mad Scientist.
https://shop.evilmadscientist.com/productsmenu/189
Opublikowany : 09/02/2021 11:07 am
1 ludzie polubili
