Radius Gauges on MMU2S
Durahl
(@durahl)
So every once in a while I need to measure the Radius of something or just need to get a grip on what size a Radius would actually look like in Real Life compared to on the Monitor where things usually look bigger than they are ( buying things based on their appearing size on a 77" TV  leads to a lot of disappointment... )
First Picture shows my entire MMU2S Setup in my Closed already housing my Formlabs Form²... i3 MK3S & MMU2S take up so much space T_T
First Batch of Radius Gauges are finished - Next to it a Medical Pillbox I made before the installing the Filament Retract Bank.
Second Picture showing the entire Radius Gauge Set still in separate form.
Third Picture showing the Pin holding them all together being printed and the Gauges stacked on top after the Print reached a certain height.
The last Picture showing the combined Radius Gauges forming a neat little Fan of some sorts =)
Probably not the MOST accurate thing but it should at least provide a little help when measuring things =)
Napsal : 25/08/2019 4:54 pm
1 lidem se líbí
