Multi-coloured cell
PJR
 PJR
(@pjr)
Antient Member Moderator
Multi-coloured cell
https://www.thingiverse.com/thing:2485063
Yellow needs a little more purge; darker colours could be slightly less. 0.2mm layers, 40mm purge for all filaments, 10h 33m.
Peter
Respondido : 20/10/2017 10:55 pm
1 les gusta
Shree Kumar
(@shree-kumar)
Re: Multi-coloured cell
Nice ! I had seen that model on Thingiverse & instantly thought "good for MM".
Curious - do you get a better surface finish/less stringing on the direct drive printer v/s the MM ?
Respondido : 21/10/2017 2:14 pm
PJR
 PJR
(@pjr)
No and no. KISS has Preload function, which does much the same as linear advance. On the MM, retraction is 2.5mm on one printer and 1.5 on the other.
Peter
Respondido : 21/10/2017 10:13 pm
Annmarie
(@annmarie)
RE: Multi-coloured cell
Hello
 I am ordering a MMU.  Did you clue these parts together or print it all at once?
Respondido : 30/03/2022 12:12 pm
Annmarie
(@annmarie)
*glue
Respondido : 30/03/2022 12:57 pm
