Lithophane lampshade
Aki.K
(@aki-k)
I made litlle lampshade from 360 picture. I placed 360 camera to apple tree in my yard and that picture I turn in to lithophane with
http://3dp.rocks/lithophane/ web app.
I use Filamentum PLA with Slic3r normal settings with 0.2 layer and so on. Only thing what I changed was Infill to 100.
Lampshade 18 cm wide and 17 cm high.
With light on you can see layers, so I should maybe put little bit higher temp to nozzle..?
Napsal : 27/09/2017 11:56 am
e.b
 e.b
(@e-b)
Re: Lithophane lampshade
Wow ! Superb !
Napsal : 28/10/2017 5:03 pm
RandomSky
(@randomsky)
Wow that is awesome, I have been struggling with making a lithopane. Never seems to come out right.
Did you do any photo editing before using http://3dp.rocks/lithophane/ ?
Napsal : 23/04/2018 4:44 pm
Aki.K
(@aki-k)
Thank you,
No I did not edit photo before
But web app crashes with actual size, I think that reason is my old computer and bad network connection.
So I scale it up little bit slic3r
Edit:
I follow this instructions
Only differense that I use slic3r
Napsal : 24/04/2018 6:56 pm
onit12
(@onit12)
Hi there,
I know it is not the topic, and sorry aki.k that i could not help you.
I am also trying to print some lithophanes, but my problem is that the images are after going through http://3dp.rocks/lithophane , importing into Slic3r and rotating 90° around Y-axes the picture is not entirely on the bed. I don`t know how to get this thing down....
Please have a look:
Any ideas?
Thanks and greetings from Austria
Tino
Napsal : 26/04/2018 8:23 am
onit12
(@onit12)
seems the link is not working, so here is the screenshot
https://www.amazon.de/clouddrive/share/zLqn349v7edmz8glByx4kZ0mh4GsdtFhzaVouqRLXkW
Napsal : 26/04/2018 8:24 am
tom.b6
(@tom-b6)
All of the lithophanes I've created using that site are damaged/defective when it comes to loading them in Slic3r. I always need to repair them.
To do this, I import them into the Windows 10 3DBuilder program. They will automatically get repaired. There's also a "Settle" option that may be needed with yours although that has not been a problem for me.
Once I save them as a new .stl, they work fine in Slic3r.
Napsal : 01/05/2018 1:28 pm
RandomSky
(@randomsky)
Thanks all,
tom.b6 - cannot believe I missed the errors in Slic3r. Thanks for reminder. Hopefully this time it will successful.
Napsal : 08/05/2018 11:11 pm
