Head of David by Michelangelo - toothbrush / makeup brush holder
conflag
(@conflag)
Hey there,
just wanted to share a print - I modified a head of David sculpture by Michelangelo - all kinds of cool historic sculptures can be found on SCAN THE WORLD webpage.
I have then edited it with Meshmixer to create holes: 18x2.2mm hole for the glued-in 17x2mm magnet on the bottom, and a cylindrical hole on top of the head. Maybe the hole could be a bit deeper, but it is what it is.
Filament used is Stone Age PLA (manufacturer: Spectrum Filaments), printed on a prusa MINI+ with 0.25 nozzle and 0.12 layer height, for about 32h. It could probably easily be done with a 0.4 and 0.15 quality default preset without any problems, and within less time, but I was too lazy to change the nozzle to reduce print time this time around.
It needed a few supports from the bottom of his head, and it was printed "face up".
I don't know if without magnets it would be viable in terms of balance, but for my bathroom setup and the metal shelf I have next to the mirror it seems perfect 🙂 There's also alternatives to get something heavy into the base, or do a gradient infill in slicer, so that it's heavier on the bottom and lighter on the top.
Hope you like it 🙂
This topic was modified 5 years temu 2 times by conflag
Opublikowany : 24/08/2021 3:09 pm
1 ludzie polubili
pencil cup
Very nice desing!  I might use somthing likme this as a pencil cup.
Opublikowany : 24/08/2021 5:13 pm
1 ludzie polubili
