Going small... Fun with small nozzles
I've decided to see how small I could print a recognizable print. So far, I'm down to 1:300 miniatures printed in PLA with a 0.15mm nozzle. It doesn't look great zoomed in, but at 100% size, the strings aren't visible and it's clearly a Jeep. I'm not sure how to paint anything like this, but it does open up possibilities for tabletop miniatures and dioramas at small scale.
Postato : 15/11/2020 2:07 am
3 persone hanno apprezzato
RE: Going small... Fun with small nozzles
Posted by: @bobstro
Already looks good!
I have also tried to create a multicolor print with a 0.1mm nozzle, but a uniform extrusion is very difficult to achieve:
I think that the mechanical limits of the Prusa have been reached.
Postato : 15/11/2020 2:27 am
1 persone hanno apprezzato
1:600 is a bit too far...
1:300 seems to be the lower limit for recognizable models.
Postato : 15/11/2020 5:34 am
Posted by: @karl-herbert
Up close everything looks bad, but at any distance the text looks really good. Would a darker base color hide the blurring?
Postato : 15/11/2020 5:35 am
I decided to go all-out and try a range of scales. Here are a pair of miniatures at (from left-to-right) 1:600/3mm, 1:285/6mm, 1:200 and 1:100/15mm scales. The smaller khaki prints are all done on the Mk3 with a 0.15mm nozzle at 0.08mm layer heights with Paramount PLA, the gray with a 0.3mm nozzle at 0.15mm layer heights with Atomic PLA.
Zoomed in, FDM will always look poor compared to resin, but I'm really happy with these results at actual size. On a table of foam and felt scenery, they are quite usable, particularly at 3 feet or more.
Postato : 16/11/2020 11:32 pm
4 persone hanno apprezzato
Utenti
Pretty cool.  Playing Axis and Allies?
Postato : 17/11/2020 12:15 am
I think I've asked this before: but that tank barrel is impressive. Supports or is that a two part print? And, lack of wipe artifacts is impressive.
Postato : 17/11/2020 1:09 am
Posted by: @charles-h13
We played Flames of Wars (1:100/15mm) when my sons were young. They're off on their own 10 years now, but asked for some to play some nostalgia games over the winter. I'm having fun producing the pieces en masse even if I can't play.
Postato : 17/11/2020 5:36 am
Posted by: @tim-m30
I'm getting very nice supports out of ideaMaker lately. Turrets and hulls are each one piece, printed as they stand. I've been able to disable wipe since getting the filament extrusion multipliers and LA tuned. The Atomic filament prints very well, and Paramount is almost as good, which helps a lot.
Postato : 17/11/2020 5:39 am
Swiss_Cheese
(@swiss_cheese)
My goodness! that Sharpie is HUGE!
The Filament Whisperer
Postato : 23/11/2020 12:14 am
