First print with NinjaFlex
Willywidget
(@willywidget)
I thought I would share my first print with Ninjaflex. I think it came out very well. I used the Slic3r, printer and material profiles provided with the printer. I had an initial issue trying to load the filament. I found the load function's speed is too high. This caused the filament to fold back on itself and a loop of filament began to come out of the viewing port on the side of the extruder. It was still enough to purge the previous print material (ABS) from the nozzle. I loaded the file on the SD card. I pulled the filament back out of the extruder and cut a clean end on it. I then pulled the idler back and slid the filament as far down as it would go. Then started my print. This was successful.
Respondido : 11/04/2016 3:45 am
Scott
(@scott)
Re: First print with NinjaFlex
It looks great. I started printing Nylon and it works great too. The Pursa i3 is a amazing printer.
Respondido : 11/04/2016 7:59 pm
Willywidget
(@willywidget)
Went little wild with my sample of Ninjaflex.
Respondido : 12/04/2016 5:18 am
Willywidget
(@willywidget)
Oh and I printed a phone case.
Respondido : 12/04/2016 5:20 am
christophe.p
(@christophe-p)
Miembro Moderator
That's nice ! I Thanks for the tip to load the filament, it will be wisely used 😉
I'm wondering what process could be used to finish object using NinjaFlex, like using aceton vapors for ABS.
I'm like Jon Snow, I know nothing.
Respondido : 13/04/2016 10:30 pm
