Black filament
fra1887
(@fra1887)
Black filament
Hello to all,
in the last period I find black filaments that should not be on the prints, this has been happening since I mounted the hardened steel extruder.
Can you give me some information on this phenomenon and how to avoid it?
Thank you
Postato : 12/08/2018 9:11 am
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: Black filament
That's burned filament leaking from the heater block because you did not follow the instructions when changing the nozzle 🙁
There's a good assembly guide here: https://e3d-online.dozuki.com/Guide/V6+Assembly/6
Peter
Postato : 12/08/2018 12:09 pm
fra1887
(@fra1887)
Re: Black filament
Thanks for the answer, but where does it come from?
Postato : 13/08/2018 10:59 am
