Best print so far
brian.d11
(@brian-d11)
Best print so far
Scaled this model up 280% from thingiverse. Rough size is 280x200x140. 23 hour print. .2mm layer height, 15% infill printed at 100% feed rate using Prusa gray pla. Standard prusa setting for pla. A few have suggested using a little higher extruder temps. Will try next time and see what happens. Next stop ABS.
Napsal : 09/04/2018 1:06 am
rob.l6
(@rob-l6)
Re: Best print so far
Nice head!
Napsal : 09/04/2018 4:51 am
Lee
 Lee
(@lee)
Mk3 print volume is 250mm x 210mm x 210mm ?
Napsal : 09/04/2018 10:32 am
warren.l
(@warren-l)
That is why I bought a Prusa! Looks fantastic. Now if the printer would only arrive...
Napsal : 09/04/2018 1:56 pm
Peter L
(@peter-l)
Now that's how you get a head in life!
Napsal : 09/04/2018 11:53 pm
brian.d11
(@brian-d11)
Sorry for the bad math 😥 Embarrassment to the engineering field. Let's try this again. 7"x6"x6" or 180x150x150. Ugh. And I wasn't even drinking. 😳 Scaling the STL. file shows lots of facets. Really no way to fix the file either.
Napsal : 10/04/2018 12:35 am
BillC
(@billc)
Meshmixer - free from Autodesk
Netfabb Basic - also free from Autodesk - just resist the temptation to click upgrade unless you are ready to sell your car/house/spouse.
Bill
Tagaytay City, Philippines
Napsal : 10/04/2018 7:19 am
peter.b37
(@peter-b37)
Never do this kind of high level maths without drinking first, you could injure yourself 🙂
There are lots of different ways to smooth out a model, any decent 3D program (Lightwave, C4D, Blender . . . etc) will allow you to subdivide a surface in numerous ways.
Napsal : 10/04/2018 11:28 am
Lee
 Lee
(@lee)
There are lots of different ways to smooth out a model.
Any decent 3D program (Lightwave, C4D, Blender . . . etc) will allow you to subdivide a surface in numerous ways.
Here, I made you a very quick example . . . original STL on the left, I then subdivided x1 and then x2 . . .
Napsal : 10/04/2018 11:30 am
brian.d11
(@brian-d11)
Thanks Lee for the information. My background is design and cnc machining. Solidworks and Mastercam. I'll dig into editing stl files soon. I have tried in solidworks but it takes forever to convert from point clouds to stl to surfaces. We scan parts and compare using a Romer Arm but when we need to convert the files to surfaces I send it out to a company that uses Geomagic. Usually the surface files come back very clean and are easy to machine.
Napsal : 11/04/2018 12:50 am
Lee
 Lee
(@lee)
Grab yourself Blender, it's free for Mac/Windows/Unix - and pretty much covers everything you'll find in 3D packages like C4D that can cost $1,500+
Yeah, I think there is a divide between the more CAD type programs and the more 3D animation type programs, they each tend to offer different sorts of tools, I come from the more the '3D animation type programs' side of things (used to be an animator), where doing something like smoothing out or subdividing a surface is - quite literally - a 3 or 4 second job . . . . but there are probably things you could do quickly and easily in CAD that would take me forever in C4D or bender.
Might have to learn me some CAD !
Napsal : 11/04/2018 10:02 am
Dewey79
(@dewey79)
I was going to say that's why he's ducking his head, chin down to fit inside the print area....
Napsal : 13/04/2018 4:46 am
mklabunde
(@mklabunde)
yeah I know what you mean. I got an email with a ups shipping number and it tracks yippee!!!! Says I should get mine on Thursday can't wait. workbench is all set for the great assembly day/s
Napsal : 14/04/2018 10:47 pm
roman.c3
(@roman-c3)
Where did you find this "head". Can't find it on Thingverse...
Thanks for any hint or link to find it.
Napsal : 18/04/2018 4:34 pm
brian.d11
(@brian-d11)
I found it on Pinshape. Search for Zombie Head. If you want to print it as large as what I did, please take the advice of some of the post and refine the stl. Love to see the print after it is refined. The one I printed but you can see the facets. Not bad but if your going to print it might as well make it look good. I do not think it will add much time.
Napsal : 19/04/2018 1:21 am
