AKOFS Seafarer Well Intervention Vessel (1:120 scale)
Andreas Swane
(@andreas-swane)
Utenti
I have printed the Well Intervention Vessel ‘AKOFS Seafarer’ (former Skandi Aker) using a Prusa i3 MK3S+ 3D printer.
The hull was printed in 7 sections to fit the print bed, and each and every detail and component was printed individually, showcasing the level of detail and care put into this project. I used vanilla white PLA for the print and painted it afterward.
This is my first time printing something as extensive and detailed. I learned a lot on the way, so it will be even better next time. I will definitely do things differently.
Scale: 1:120 (TT scale)
Weight: 7072 g
Dimensions: 230 mm width, 1350 mm long, and 590 mm from bottom to top of tower.
I hope you like it. 🙂
Questa discussione è stata modificata 1 year fa 3 tempo da Andreas Swane
Postato : 25/07/2024 12:09 pm
19 persone hanno apprezzato
Kadora
(@kadora)
Utenti
RE: AKOFS Seafarer Well Intervention Vessel (1:120 scale)
Hello Andreas excellent work.
The most detailed 3d printed  model I have ever seen.
How many parts contains your beauty  and how long time took building ?
Thank you
Postato : 30/07/2024 9:32 am
1 persone hanno apprezzato
Amigagoma
(@amigagoma)
Good job , very detailed, very nice rendering. Does the boat float?
Postato : 01/08/2024 7:03 am
gday
 gday
(@gday)
Utenti
Very impressive, nice job.  Many hours well spent.  I work with those S92 helicopters 🙂
Postato : 06/03/2025 10:56 pm
Antimix
(@antimix)
Very nice model. 🤩
Are the text 3d printed or are they adhesive ?
Best Regards
Postato : 27/03/2025 7:37 pm
Andreas Swane
(@andreas-swane)
Utenti
Thanks. 🙂
I embossed the text and logos in the print and painted over with a white Posca pen. I have learned a lot on newer projects since this one. If I had done this project again, I would have done the painting and lack of smoothing better with spray fillers.
Postato : 28/03/2025 10:17 am
Staldy
(@staldy)
Very impressive, a lot of details, congratulations for this amazing work.
Postato : 28/03/2025 12:01 pm
sqalce
(@sqalce)
Utenti
what an absolutely perfect model!
is it by any chance possible to get the STL files?
Postato : 21/09/2025 2:07 pm
