A nixie project
tsamisa
(@tsamisa)
A nixie project
Lately i find myself complaining a tiny bit about prusa's printers. But in all fairness they actually produced great results on my projects. Following is an approach for a Nixie clock i build when i first got my XL. I uses the XL for functioning parts, my SLS for cosmetic and detail ones, my cnc for wood processing and my smaller engraver for  pcbs. It uses a nixie bar for temperature or second reading , according to a levers positions , humidity meter and motion detection.
Napsal : 03/08/2025 7:19 am
5 lidem se líbí
James Kirk
(@james-kirk)
RE: A nixie project
Cool.
How do you drive the nixie tubes?
I have built some nixie clocks as well.
For the first one, I did the whole electronics by myself (with an arduino nano), and later I used the arduinix board, but I added a RTC module.
The last one uses a nixie driver board from aliexpress.
On the pictures not all digits are visible, because of the shutter speed.
Napsal : 30/08/2025 9:05 am
1 lidem se líbí
D O
 D O
(@d-o)
RE: A nixie project
REAL nixie tubes. Cool! Well...not cool. They put off a fair amount of heat...Much of my test equipment was nixie tubes back when I started in electronics.
Napsal : 02/09/2025 2:11 am
1 lidem se líbí
James Kirk
(@james-kirk)
RE: A nixie project
The nixie tubes do not really produce a lot of heat.
The glowing is not because of heat as it is in a regular light bulb, but it is a glow (gas) discharge.
Napsal : 02/09/2025 5:53 pm
tsamisa
(@tsamisa)
RE: A nixie project
I actually use an arduino nano for the nixie digits along with a couple of 74HC595 SR and 4 nixie drivers. For the bar i made current regulator circuit. The humidity indicator its just a servo with a dht22. I just love the retro feeling of nixies.
Napsal : 02/09/2025 8:28 pm
1 lidem se líbí
MartyParr
(@martyparr)
RE: A nixie project
Very cool project! Nicely done
Napsal : 04/09/2025 7:42 am
tsamisa
(@tsamisa)
RE: A nixie project
Thanks 🙂
Napsal : 04/09/2025 1:54 pm
