MK3S MMU2 octoprint help needed
BDR529
(@bdr529)
as a new user I/m a little bit lost becaus if I print via octoprint  bed and nozzle are not heated.
Do I print the same file vis sd card directly on the printer it works
env.hardware.cores: 4env.hardware.freq: 1800.0env.hardware.ram: 8228569088env.os.bits: 32env.os.id: linuxenv.os.platform: linuxenv.plugins.pi_support.model: Raspberry Pi 4 Model B Rev 1.5env.plugins.pi_support.throttle_check_enabled: Trueenv.plugins.pi_support.throttle_check_functional: Trueenv.plugins.pi_support.throttle_state: 0x0env.python.pip: 22.2.2env.python.version: 3.9.2env.python.virtualenv: Trueoctoprint.last_safe_mode.date: 2022-09-07T13:21:48Zoctoprint.last_safe_mode.reason: settingsoctoprint.safe_mode: Falseoctoprint.version: 1.8.2printer.firmware: Prusa-Firmware 3.11.0 based on Marlinsysteminfo.generated: 2022-09-08T09:11:25Zsysteminfo.generator: zipapi
Postato : 08/09/2022 10:18 am
