PrusaSlicer 2.8 Farbwechsel per Tastatur nicht möglich
fabian
(@fabian)
Vor der aktuellen Version PrusaSlicer 2.8 war es möglich mit den Tasten „+“ und „-„ einen Farbwechsel einzufügen oder zu entfernen. Jetzt muss man für den Farbwechsel mit der Maus auf das Plus drücken, per Tastatur geht nicht mehr. Wo kann ich das wieder einschalten? Danke!!
Postato : 05/07/2024 3:09 pm
RE: PrusaSlicer 2.8 Farbwechsel per Tastatur nicht möglich
Pull the top orange marker down to where you want the colour change, then you should be able to mouse click at that level to set the colour change
Postato : 05/07/2024 5:05 pm
Digibike
(@digibike)
Yes, but he asks about the older Versions of Prusa Slicer he don´t need the Mouse Click to change. He can made it, with the Keyboard-Key "+" do it. But since 2.8 it is no longer active. So he ask, how he can switch the behavior back on, if it is still there, because in his workflow he moves the mouse to the area and then presses the "+" button instead of clicking around with the mouse...
It looks, that they had chancelt this function?
Posted by: @joantabb
Postato : 05/07/2024 8:33 pm
