Simplify3D (S3D) settings for the Original Prusa printers
Jakub Dolezal
(@jakub-dolezal)
Utenti Admin
Good News Everyone!
Josef and his team created a bundle of settings for the Simplify3D (S3D) software! After rigorous testing, we are happy to add support for Original Prusa printers. Use our step-by-step guide to import the settings 😉
Link to the guide (includes the package with settings):
https://help.prusa3d.com/en/guide/how-to-import-profiles-to-simplify3d-4-x-windows-macos_18360
Direct link to the settings:
Supported printers:
Original Prusa MINI
Original Prusa i3 MK3S
Original Prusa i3 MK2.5S
Original Prusa i3 MK2/S
Supported materials:
Prusament PLA
Prusament PETG
Prusa PLA
Prusa PETG
Prusa ABS
Supported OS:
Microsoft Windows
Apple macOS
Changelog:
07/2020
Version 1.1
- Support for Original Prusa MINI
04/2019
Version 1.0 [initial release]
- Support for Original Prusa i3 MK3S / MK3
- Support for Original Prusa i3 MK2.5S / MK2.5 / MK2S
- Support for Prusament PLA / PETG
- Support for Prusa ABS / PETG / PLA
- Tested on S3D 4.1.2 x64
Happy printing, looking forward to your feedback and printing results 😉
Questa discussione è stata modificata 6 years fa da Jakub Dolezal
Assembly manuals
/ Knowledge Base
Postato : 03/09/2020 10:40 am
doktor
(@doktor)
RE: Simplify3D (S3D) settings for the Original Prusa printers
My mk3s kit has just been assembled. Before Prusa, I was using s3d. However, I've added that profile and slice it. Starts printing without waiting for heating, am I missing something?
https://prnt.sc/vnlkb0
S3D version: 4.1.2
MK3s firmware: 3.9.1
Questo post è stato modificato 6 years fa da doktor
Postato : 21/11/2020 11:53 pm
bix
 bix
(@bix)
@doktor
Same situation - just finished building the printer. With S3D, prints don't wait for temperature. Did you ever get a reply or a fix to your post?
Postato : 06/05/2021 12:42 pm
doktor
(@doktor)
@bix
No, as you can see. But doesn t a problem. You can use custom gcode for waiting few minutes before printing. I haven t tried yet.
Postato : 06/05/2021 1:32 pm
With the advances in other slicers I haven't used Simplify 3D much in over a year, but I recall that it looks for nozzle and bed heating commands in the start gcode (e.g., M104, M109) and if those are missing, inserts them. I believe this is controlled with the Wait for temperature controller to stabilize before beginning build setting under Temperatures. If you don't have those commands in your custom gcode, you likely need to enable this setting. There may be situations where it doesn't properly identify those gcode commands.
Sorry I can't recall the specifics. I've got some example S3D start gcode here that you can compare. Suffice to say that once you get it set up correctly, Simplify 3D can be used with the Prusa printers just fine.
Postato : 06/05/2021 2:36 pm
1 persone hanno apprezzato
towlerg
(@towlerg)
You need to add Custom GCode. ie
M190 S[first_layer_bed_temperature] ; wait for bed temp\n
M109 S[first_layer_temperature] ; wait for extruder temp\n
Postato : 06/05/2021 2:43 pm
2 persone hanno apprezzato
I have the temperatures for Simplify 3D set as follows:
M104 S{material_print_temperature_layer_0} ; set extruder final temp
M109 S{material_print_temperature_layer_0} ; wait for extruder final temp
M190 S{material_bed_temperature_layer_0} ; wait for bed final temp
Note the curly braces ({}) used for shortcuts in S3D rather than square brackets ([]) used in PrusaSlicer.
Postato : 06/05/2021 4:25 pm
