Prusaslicer print time is almost twice as long as Cura is that normal?
J P
 J P
(@j-p)
Im printing on the Neptune 3 pro. My main slicer is Cura but wanted to try out Prusaslicer 2.6.0 alpha 3. When I import the same STL into both. I have the settings as close to the same as I can see other then speed. The print times after slicing after almost double of that of Cura. Im thinking it's speed related as the speed setting, just not sure what I need to change in Prusa. Thanks for any help
Postato : 14/02/2023 12:40 am
RE: Prusaslicer print time is almost twice as long as Cura is that normal?
Its never just speed.  What is the part ?  is it a small part for example, as PS has a slow down if layer time is below xx setting.  There are hundreds of setting combinations it could be.  Impossible to say with the information at hand.
Postato : 14/02/2023 10:49 am
