Odd toolpaths generated by cura
hawai
(@hawai)
Hi everybody,
I am normally using PS but to have a play with the different infill patterns I wanted to give cura (V 4.10.0, Prusa supplied printer profile imported) a try. After some initial hickups (Thanks @jsw fpr your help) I finally got the thing to slice my piece. Out of curiosity I ran the gcode through a visualizer and this is the somewhat exotic toolpath I found on two layers:
Is this normal behaviour for cura?
Cheers
Hansjoerg
Opublikowany : 25/08/2021 11:09 pm
Octoprint
Are you using octoprint and octolapse?
Opublikowany : 05/09/2021 11:27 am
hawai
(@hawai)
yes?
As a matter of fact I do.
Does this question lead to the suggestion I am suspecting? Ignore the preview, print it anyway and run the timelapse to see if it's real?
Opublikowany : 06/09/2021 1:51 am
print
Posted by: @hawai
I   Print it and see it occurs.
Opublikowany : 06/09/2021 11:44 am
