Infill before walls not working?
Hi, has anyone been having success with getting the slice to actually support 'infill before walls'?
I have the 'infill before walls' checked, and I read somewhere that I can't have 'optimize travel' enabled as well, but alas, I've tried to find a combination of settings / features enabled/disabled that would get the print to actually respect this option, but it never seems to work.
Just curious what others have done to get it to work (if it works), did it work OOTB or did you have to do something special?
I'm using version 4.12.1 of CURA
Opublikowany : 01/01/2022 8:42 pm
RE: Infill before walls not working?
You can either disable the infill before walls feature or lower the infill density to less than 100% to fix this.
Opublikowany : 13/09/2023 5:46 am
