RE: Help with PETG and Cura
Please use prusaslicer and objetos very prety
Postato : 29/08/2020 10:47 pm
I use Cura as kind of a backup slicer to Prusaslicer when it does not do what I expect, however, I don't remember using Cura for any PETg, so take this with a grain of salt.
The one thing I found out when using Cura with the MK3S is that some of the speeds, particularly the first layer speeds, are much too fast. I'm not on the machine that I slice on right now, so I can't do a comparison.
If you will post the .stl file for your cube (you will need to enclose it in a .zip for the forum to accept it) I'm willing to do a test print sliced with Cura and print it in PETg to see if I get the same results.
Postato : 30/08/2020 2:38 pm
Hey, JSW. I agree with you.
Postato : 24/09/2020 8:35 am
