Cura issues on corners, compensating when i dont want it to maybe?
I have some under extrusion happening on the inside of the above part it lines up with where cura shows breaks in the extrusion line (on the corners you can see "cake slices" missing from the lines, I have tried turning off compensate for inner walls and preview still shows the above breaks in the lines. Fairly certain this is what is causing the issue as I have no under extrusion visable elsewhere.
Does anyone know which setting effects this cornering compensations? or is this normal and my issue else where
Many thanks in advance
Respondido : 08/05/2020 5:54 pm
