Cura elephant foot compensation, what values do you use?
jsw
 jsw
(@jsw)
Might as well ask this one here too?  😉
I've never had any significant issue with elephant's foot, until today when I printed a few small spacers.
The pop-up says to use negative numbers to compensate for elephant foot, and I've tried -.05mm, -1mm, -1.5mm with little if any effect.  (PS seems to default to .2mm and I have never had any issues with elephant foot on PS, just with Cura, and with smaller objects.)
All of those still give about a .1-.2mm ridge on the bottom, which I have to remove with the Dremel in order to get them to fit.
I'm curious as to what numbers others are using.
Thanks.
Opublikowany : 30/05/2022 12:21 am
