Thickness of shield from plexiglass
Paola
(@paola)
What is the thickness of  shield from plexiglass?
If someone can tell me where I can buy them? and how much those cost?
Publié : 26/03/2020 9:42 pm
Steve
(@steve)
RE: Thickness of shield from plexiglass
The community edition (and myself and some other people I know who don't have a laser cutter) ended up using laminating pouches. They're not as transparent as plexi but since the shields are 1-use only it's not that bad. The thickness should definitely be 125 microns or more for the laminating pouches. 80 is too flimsy. I assume the same thing applies to "regular" shields. The normal material used for the shields is APET and I think you can by that on rolls for cutting but I can't help you with that.
XL (5T) / CORE One / MK3S+-MMU3 / MK3S / Mini / SL1S
Publié : 27/03/2020 7:52 am
Fred Meijer
(@fred-meijer)
In Holland I bought PET sheet from Toemen Modelbouw. The protective foil on the sheets says: Covestro Vivak. Maybe this helps people finding the right sheets. I used 0,5 mm but 0,75 also fits in the Prusa head band frame. Sheets are 50 x 25cm
Publié : 27/03/2020 3:15 pm
Phil
 Phil
(@phil)
@fred-m8
Are these easy to cut and if so, how do you cut them?
Cheers
Phil
Publié : 02/04/2020 2:19 pm
Fred Meijer
(@fred-meijer)
Kitchen scissors and perforator for the holes - easy.
BTW I used the carton inner part of a Prusament reel for the lower corners.
Publié : 02/04/2020 3:13 pm
1 personnes ont aimé
