Mask print - Mid-layer Shift
Panic. I does anyone know what might be causing this layer slip mid print? Everything was working fine with PLA. This is my 3rd attempt with PETG - the 1st was good and the 2nd had a slight slip, this one is obviously unacceptable. I'm trying PLA again to see if this is machine or material related, but in the meantime, does anyone have any suggestions?
i am getting this on 2 printers and have noticed it always happens on the layer above the ‘Prusa’ logo. I am using ctc a10 printers and PLA. It’s all quite new to me so if you have any insights I would welcome them
RE: Mask print - Mid-layer Shift
looks like a layer shift. I would check the belt status (in the support menu) and look at the troubleshooting guide for layer shifts in the knowledge base. The article is very helpful
