Improved top protection with top visor "crown"
We have added a protective "crown" via a second visor sheet. It uses the same mounting holes, one additional sheet and is held in place with a zip tie. The doctor using this said that the head protection was preferred over their previous commercial shields.
We are using 3mm laminated pouches because we do not need optical clarity or rigidity.
SVG file and manual cut diagram is available here. (Original SVG from Maker Nexus shield project, modified by Michelle Schlingo)
Posted : 27/03/2020 5:54 pm
