when adding MK3S+ and brand new install of Prusa link, get 404 not found from connect.prusa3d.com
when configuring a brand new install of Prusalink on a Pi Zero2, the wizard goes all the way to the end, talks to the printer, etc. but when it goes to register with Prusa connect, I get a 404 in the browser window that pops up.
I've tried 3 revs back, same issue. looks like this URL has not changed for 4 years. broken in prod?
the URL it's attempting to use:
https://connect.prusa3d.com/add-printer/connect/1.3.1/ [code]?location[location]
1.3.1 seems to map to the MK3S+.
I see others complaining about this on the Prusa link GitHub issues as well.
RE: when adding MK3S+ and brand new install of Prusa link, get 404 not found from connect.prusa3d.com
it did register one time, but I had an issue with the SD card , and did a fresh install on another SD card but now breaks.
it looks like the [code] element is a one time use and comes from the printer itself? How does one re-register if the first OS install of Prusalink was lost?
