Upload to MK4 fails with "HTTP 414: 414: URI Too Long"
jvasileff
(@jvasileff)
Uploading a file named "Accessories/PETG/Spool Adapter Jessie x8 0.4n_0.2mm_PETG_MK4IS_2h45m.gcode" from PrusaSlicer results in an error "HTTP 414: 414: URI Too Long". The upload works if you reduce the length of the filename by a few characters.
Using wireshark, I can tell the request to PrusaLink that fails is "PUT /api/v1/files/usb/...".
Respondido : 25/07/2023 2:47 pm
1 les gusta
Fred Durand
(@fred-durand)
Miembro
RE: Upload to MK4 fails with "HTTP 414: 414: URI Too Long"
2 days ago, it worked once, then an hour after, got the same isue.
for noreason, today, it worked perfect.
Respondido : 25/07/2023 8:07 pm
jvasileff
(@jvasileff)
The workaround is to use a shorter filename. But the max length limit is way to short.
Posted by: @fred-durand
Respondido : 25/07/2023 8:16 pm
