Unable to delete in Print files
Fred
 Fred
(@fred-7)
Hello,
With the new BGCODEs, it is no longer possible to delete them in Printer files - the Delete from printer button is greyed out.
it would be great if it worked again and in the file details there is the button with the impossible answer
This topic was modified 2 years temu 2 times by Fred
Opublikowany : 28/11/2023 4:36 pm
Tojik
(@tojik)
Member Moderator
Files that did not finish uploading are now hard to get rid of, we know about that one. We are just glad they print ok right now
What exactly happened during uploading? Did the upload finish properly? Can the file be removed from the PrusaLink web interface
Thank you for the feedback
Opublikowany : 04/12/2023 4:15 pm
Honolulu
(@honolulu)
RE: Unable to delete in Print files
habe das selbe problem der cloud speicher ist foll und trotz löschen der prusa links g codes wird der speicher nicht kleiner so dass ich mit connect nichts anfangen kann da ich immer fehlermeldungen beim übertragen zum drucker habe. hat da jemand eine lösung dazu?
Opublikowany : 06/12/2023 6:06 pm
