The temperature cannot be changed while you are printing
Mariusmk3
(@mariusmk3)
Membre
When I'm printing and you want to change the temperature of both the base and the nozzle in PrusaConnect it is not changed.
Publié : 24/09/2021 4:43 pm
crussty
(@crussty)
Membre
I've experienced this also
I have experienced this also. Was able to adjust temperatures from the LCD *IF* model being printed is on the SD card, but not if the model is stored on the Pi.  In either scenario, was NOT able to adjust temps from the PrusaConnect interface.
De do do do de da da da... Is all I want to say to you...
Publié : 27/09/2021 5:01 pm
marcomania
(@marcomania)
Membre
same experience
same experience here, no change via the webinterface and no entry in the log. via the printer the temperature can be changed, here also for a file that is stored on the pi. The webinterface then shows the changed temperature...
Publié : 28/09/2021 12:50 pm
