Telegram and Discord gives " invalid endpoint URL"
jonasbno
(@jonasbno)
Prusa mk4
firmware: 5.1.2+13478
Problem:
I have followed the guide to telegram bot. I get the message saying
"Hi, I am your first notification, thank you for using them. You can adjust the sending of notifications according to your wishes."
I also get the evrything is OK "check" on prusa connect
Then on the first notification the checkmark change to a error mark saying something like " invalid endpoint URL"
I then tried the same with Dicord. Got the same initial message. ANd on the first finished print when the message should go out. I get "invalid endpoint URL" in the prusa connect backend.
Tried:
Delete and adding again. The same happens. New initial message and then Error on the first try to deliver notification.
I also found this post: https://forum.prusa3d.com/forum/general-discussion-user-experience-ideas/telegram/#post-635600 that i have not tried since i like discord best. And wanted to get Discord to work.
Any suggestion ?`
Publié : 11/01/2024 8:21 am
Tojik
(@tojik)
Membre Moderator
RE: Telegram and Discord gives " invalid endpoint URL"
Hi, please try it again. We think we've fixed it.
Publié : 11/01/2024 9:36 am
jonasbno
(@jonasbno)
Yes . Works now on both platforms 🫡
Publié : 11/01/2024 3:19 pm
1 personnes ont aimé
