RPi Zero frame doesn't fit model Rpi Zero 2 W properly
Zbigniew Trzepizur
(@zbigniew-trzepizur)
Hello
I've noticed, that the RPi Zero frame part attached to the HowTo article doesn't fit model 2W properly. Due to minor PCB layout changes in RPi Zero 2W vs RPi Zero W, the frame is pressing on some SMD passives which risks damaging them. Also, the RPi Zero 2W's miniHDMI port seems to be a bit taller overall and also not quite fit the frame, versus the one on the older RPi Zero W, at least in case of my samples. Would be nice for you guys to post an updated model, with those minor issues fixed.
Also, this is not just a humblebrag that I was somehow able to get my hands on an RPi Zero 2W 🙂
Cheers,
Zbig
Postato : 10/06/2022 11:55 am
printing overnight
(@printing-overnight)
Utenti
RE: RPi Zero frame doesn't fit model Rpi Zero 2 W properly
There's no official Prusa Solution yet, as far as I know, but others had the same problem:
https://www.printables.com/model/86489-raspberry-pi-zero-2-w-frame-for-einsy-rambo
Worked fine for me, maybe you wanna give it a try?
Postato : 10/06/2022 7:17 pm
1 persone hanno apprezzato
Zbigniew Trzepizur
Good find, thank you!
Postato : 10/06/2022 7:45 pm
