Raspberry Pi Camera No Longer Working on Prusa Connect Dashboard
DAMorganWilkins
(@damorganwilkins)
Membre
A few hours ago, the camera connected to the Raspberry Pi running Prusa Link stopped displaying on the Dashboard in Prusa Connect. Instead, it displays a "This image is more than 1 hour old" error. The camera is still connected and displays correctly in Prusa Link, and has the status "Linked" under "CONNECT". At around the same time as the issue began, I was prompted to refresh my browser for a new version of Prusa Connect, so this issue might be related to an update.
I've tried removing the camera from Prusa Connect and re-adding it in Prusa Link, as well as restarting the printer and Raspberry Pi, but this has no effect. I've also tried reducing the camera resolution and the trigger scheme, but this also has no effect.
Key info:
  • PrusaLink type - Raspberry Pi 4
  • PrusaLink version - PrusaLink 0.8.1
  • Printer type - MK3S+
  • Printer UUID - 7d245bab-0a14-46c7-9f13-40f31a320624
  • Printer firmware version - 3.14.0-8066
  • PrusaSlicer version - not relevant (the error is not isolated to PrusaSlicer)
Ce sujet a été modifié il y a 2 years par DAMorganWilkins
Publié : 03/10/2024 5:07 pm
1 personnes ont aimé
_KaszpiR_
(@_kaszpir_)
RE: Raspberry Pi Camera No Longer Working on Prusa Connect Dashboard
Some people reported similiar issues on Discord, but no response what is wrong.
Publié : 03/10/2024 8:38 pm
bferrazzi
(@bferrazzi)
Membre
I'm having the same issue.
Camera is working through the IP address but not on connect.prusa3d.
Publié : 03/10/2024 9:12 pm
Sestary
(@sestary)
Membre
Same here, I am uploading the images using the docker image from here https://github.com/jtee3d/prusa_connect_rtsp with two cameras and the program keeps returning the error "Internal Server Error" while trying to upload the processed image.
Publié : 04/10/2024 12:21 am
b2cd
 b2cd
(@b2cd)
Membre
Same here. My esp32 cams stopped working mid-afternoon on october 3.
When I log into the cams directly as a wifi access point, it says under System Status: "Prusa Connect Status   Photo: 500 - unknown error code"
In addition to power cycling all possible offending electronics, I tried de-registering the token from Prusa Connect and re-registering... to no avail!
Publié : 04/10/2024 5:47 am
Hello
(@hello)
Same here and in the app really hope it gets fixed, can someone report it on github.
Ce message a été modifié il y a 2 years par Hello
Publié : 04/10/2024 6:44 am
DAMorganWilkins
(@damorganwilkins)
Membre
It seems to have been magically fixed, as of the past half hour! Thanks Prusa!
Publié : 04/10/2024 8:17 am
