Prusaslicer cannot connect to Prusalink
[Gelöst] Prusaslicer cannot connect to Prusalink
Eef
 Eef
(@eef)
Whatever I try, I keep getting this "Prusaslicer has encoutered an error" when I try to upload a file.
I am Macbook, have good connection with Prusaprinter, can control what is needed by the webcontrol etcetera.
In Prusaslicer:
- setup a physical printer
- browsed for the Prusalink on the local net, and could easily find the entry
- copy/pasted the API key
Choose Prusalink connection
Tested: Could not connect to PrusaLink: HTTP 403: Bad X-Api-Key
What can be wrong? And how to fix this?
regards, Eef
Veröffentlicht : 21/10/2023 7:01 am
Tojik
(@tojik)
Mitglied Moderator
RE: Prusaslicer cannot connect to Prusalink
Hi, in Connect there are two API keys, if you are entering the printer IP adress into PrusaSlicer, make sure you are copying the PrusaLink one.
A lot of times people don't differentiate between Link and Connect which makes it hard to diagnose remotely
Veröffentlicht : 21/10/2023 9:05 am
Eef
 Eef
(@eef)
Thank you for your fast reply.
So I went to : http://192.168.178.101/#files
Settings, scrolled down (almost to bottom)
There I could reset the API-key
and used that in Prusaslicer, with success.  🙂
PS. And only AFTER this, in https://connect.prusa3d.com/printer I could see two API-Keys.
So looks, like the reset was needed for that.
Thank you for your help. Regards, Eef
Veröffentlicht : 21/10/2023 11:00 am
