Prusalink works only if ran in foreground
tampe125
(@tampe125)
So, this is strange.
I have 4 printers, after a power outage 2 of them are not connecting to Prusa portal. They are online, I can SSH to them. If I run
prusalink -f
I can see them connected to the portal. If I start the daemon, they are not connected. Any suggestions on how to fix this? Currently running version 0.7r2
Opublikowany : 06/06/2023 10:19 am
tampe125
(@tampe125)
RE: Prusalink works only if ran in foreground
And of course as soon as I post the problem I found the solution...
It seems that the problem was caused by the prusalink.pid file, since the daemon could not acquire the lock.
I manually removed the file /home/pi/prusalink.pid , restarted the daemon and now everything works as expected.
Hope that helps
Opublikowany : 06/06/2023 10:31 am
Tojik
(@tojik)
Member Moderator
Hi, awesome you found the solution this fast. Also, 0.7.0 (now without beeps) is out, so feel free to update. Also it has an inbuilt updater. Untested at a large scale, but i'm told it should work 😉
Opublikowany : 06/06/2023 1:02 pm
