PrusaLink with RPiZW2 crashes firmware
Philg
(@philg)
Finally got a PiZW2 and added it to my MK3S+.  When I set Settings/Port to ON I get a FW error.  Same result after resets and power cycles until I turn off Settings/Port. The pi does show up on my network.  The MK3S+ firmware is 3.12.2-5713 and the Pi image is prusalink-0.7.2. The pi pins are in the right locations and soldered well with flux.  Any help would be appreciated.
Phil
Respondido : 11/12/2023 3:22 pm
Patrick.b
(@patrick-b)
RE: PrusaLink with RPiZW2 crashes firmware
hi i have some that i don't use in case u need or other as i know it's hard to buy since years..
well , reply to your question, i set up some printer and my with the rpiow2 and really it was perfect as i see your connection are ok !! and if u plug it into the rambo that should have 0 problem ! personnaly i ony use the 3.11 fmw the last one they add many option to tet T° and more sensible so no idea if that the problem but try to update the 3.11 and just reboot , let the printer find the IP adress then after type it into your browser..
after u installt he 1mg from link it's ok and run fast,,,(better than mk4) 😊 🤫
did you set up the SD card before ? with the last little software from raspberry ? and add your SSID name AND password of your router or internet box ?
Respondido : 11/12/2023 3:41 pm
Tojik
(@tojik)
Miembro Moderator
Hi, as mentioned, please try a different FW The newest is 3.13.1 Also, if you can, send us the Debug data your printer generated. Thank you
Respondido : 13/12/2023 11:15 am
Philg
(@philg)
How do I get the debug data?
Respondido : 13/12/2023 12:54 pm
Tojik
(@tojik)
Miembro Moderator
I think they ended up on the printer SD card
Respondido : 13/12/2023 1:15 pm
Philg
(@philg)
No, it's a dump from the USB serial interface.  I have the zipped file of the dump.  How can I send it directly to you.
Respondido : 13/12/2023 9:22 pm
Tojik
(@tojik)
Miembro Moderator
Oh, it's more involved: https://help.prusa3d.com/article/crash-dump_364959 , sorry, wasn't aware of that.
Soo yea, the more important question is, does it happen on any other FW. Have you tried the newer ones?
Respondido : 20/12/2023 9:47 am
Philg
(@philg)
Sorry, I have had a couple of higher priority projects so will not not be able to try different FW until later this week.
I’m still looking for an email address to send the debug log.
philg
Respondido : 20/12/2023 1:01 pm
Philg
(@philg)
Well, I upgraded to FW 3.13.2 and still had the problem then I downgraded to 3.11.0 and still have the problem.  Whenever I turn RPi Port on, the printer crashes.  I have the crash dump waiting for someone to ask for it offline.
Respondido : 22/12/2023 7:16 pm
Tojik
(@tojik)
Miembro Moderator
How do i ask for it offline? If you dm me the log, i can ask the fw team to take a look. Personally, i never had the issue.
Also, if you can, dm me the log from PrusaLink so i can verify I am not doing something wrong. You can find that in the local web interface under settings. Please send me the syslog file.
Respondido : 24/12/2023 4:22 pm
