PrusaLink: HTTP 403: Bad X-Api-Key.
Patrick.b
(@patrick-b)
Hi
is there an option to solve this problem ? i just copy the api from prusa connect then have this answer ?, i solve many other !! Especially the link now o have to shut down and on again then prusalink work but can't add the print in prusaslicer..
Publié : 20/11/2022 11:30 am
Boosun
(@boosun)
RE: PrusaLink: HTTP 403: Bad X-Api-Key.
I don't know if you solved the problem, but since I had it too, here is the solution I found:
  1. In the physical printer configuration window (in PrusaSlicer), instead of the "API key" authorization type, choose "HTTP Digest" instead.
  2. Then enter your Prusa Connect username and password and everything should work.
  3. To check, press "test" and a message will confirm you that the connection was successful.
Tips: if the name of your file to be printed is too long, the sending may fail. Simply reduce the name and it will work.
Publié : 07/05/2023 2:15 pm
2 personnes ont aimé
Patrick.b
(@patrick-b)
Thx, but i don't use anymore since long time the API key it never work and never undertand why it never work but only the digest work well , i don't get the point why explain and write and set up the api key copy paste ..blablabla but in fact that never work..
do it simple done
at now no idea how long are the name but I never have fail on this issue..thx
Publié : 09/05/2023 8:34 am
Sir Printalot
(@sir-printalot)
Amazing - thanks!
Publié : 14/05/2023 7:17 pm
1 personnes ont aimé
