PrusaConnect Object Cancel
tattooed_pariah
(@tattooed_pariah)
Loving the prusa connect web interface/app, with one exception, and it's probably something I'm doing wrong, but just in case, thought I'd bring it up..
When I start a print by sending it from PrusaSlicer to Connect, the Cancel Object option is grayed out on the Local Panel of my mk4. Through Prusa Connect web interface, I can still select objects and send the command to cancel them. and it reports the command was sent/received successfully, but the object continues to print.
I only used this feature once or twice before I started using Connect, and it used to work, but now doesn't. Not sure what I can provide to help find the problem, or if anyone else is having the same issue.
Opublikowany : 04/03/2025 6:12 pm
tattooed_pariah
(@tattooed_pariah)
RE: PrusaConnect Object Cancel
not sure what happened, but option is no longer ghosted on the LOP and works through PC again. Thumbs up!
Opublikowany : 06/03/2025 7:37 pm
