PrusaConnect MBL 3D graph Y axis reversed
jwingenroth
(@jwingenroth)
PrusaLink type Raspberry Pi Zero
PrusaLink version 0.7.0.rc1
Printer type MK3S+
Printer UUID (you can find it in Printer detail page - address line) could not find this. Is this the MAC address?
Printer firmware version 3.11.0-4955
PrusaSlicer version (if applicable) N/A
Description of the bug, including steps to reproduce (if possible).
While making fine adjustments to the heatbed mounting hardware in order to dial in mesh bed leveling I have found that the Y values shown on the PrusaConnect 3D MBL graph are backward. Changes made to the physical location X205Y1 as indicated on the heatbed screenprint, result in change to the X205Y205 location on the 3D MBL graph.
Posted : 30/11/2022 6:57 pm
SaSp
 SaSp
(@sasp)
RE: PrusaConnect MBL 3D graph Y axis reversed
I have the same problem too. Y axis values are inverted.
Graph position x=1 y=1 coresponds to table position x=1 y=205
Graph position x=205 y=205 coresponds to table position x=205 y=1
Printer type MK3S+ (fw:3.14.1)
prusalink @raspberry pi zero 2w v0.8.1
Posted : 12/12/2024 10:06 pm
