PrusaConnect files not showing after update.
Brad
 Brad
(@brad-5)
Prusalink files gone after update.
I had a message at the bottom of my browser that said update available with a reload button and once I did that, it would no longer show my prusa connect files. I went to my laptop and I could still see and print all of my files from that until I hit reload on it as well to do the update and they disappeared on that one as well. How do I fix this or rollback that update so that I can see my files again?
Postato : 26/07/2024 2:32 am
1 persone hanno apprezzato
Mads Andrup Pedersen
(@mads-andrup-pedersen)
Utenti
RE: PrusaConnect files not showing after update.
I have the same problem with files missing on connect.prusa3d.com.
Tried to roll back PrusaLink to v0.7.2, but same odd behavior.
If I connect directly to my Raspberry Pi's IP files are visible, so I think this is something Prusa needs to fix in their end.
Postato : 26/07/2024 6:12 am
Brad
 Brad
(@brad-5)
That is what I was thinking as well. I am hoping this gets resolved very quickly because I use my printers for business purposes and finding alternative means of accessing my files is very time consuming and I can't always find the files I am looking for.
Postato : 26/07/2024 12:19 pm
Clinton
(@clinton)
Also seeing this behaviour after updating to PrusaLink 0.8.1. No files visible in PrusaConnect but I can see them by connecting directly to the printer. Here's my version info:
API: 2.0.0
Firmware: 3.14.0-8066
Server:0.8.1
Text: PrusaLink 0.8.1
SDK: 0.8.1
Frontend: 3.12.0
Postato : 28/07/2024 1:25 pm
NTRoPY
(@ntropy)
Utenti
I posted about a similar issue in this forum - "PrusaConnect Printer File Listing Issue"
I got around it by uploading new gcode files using PrusaConnect instead of PrusaSlicer or PrusaLink. You'll first need to delete the new files that caused the files to stop showing up on PrusaConnect from the printer. Sounds like Prusa has to fix this on their end.
Postato : 28/07/2024 4:49 pm
