PrusaConnect Camera API issue with fingerprint
[Résolu] PrusaConnect Camera API issue with fingerprint
Pitel
(@pitel)
I'm trying ot make an Android app, so the phone could be used as a camera, even when the phone is locked and the app is in background.
Anyway, When I'm sending the inital info request, everything works fine:
--> PUT  https://webcam.connect.prusa3d.com/c/info  h2
Token: qJ6yPMKEK32vrrj8EjU1
Fingerprint: google/oriole_beta/oriole:14/U1B1.230908.003/10811961:user/release-keys
Content-Type: application/json; charset=utf-8
Content-Length: 56
Host: webcam.connect.prusa3d.com
Connection: Keep-Alive
Accept-Encoding: gzip
User-Agent: okhttp/4.11.0
{"config":{"name":"Pixel 6","trigger_scheme":"TEN_SEC"}}
--> END PUT (56-byte body)
<-- 200  https://webcam.connect.prusa3d.com/c/info  (116ms)
date: Thu, 21 Sep 2023 09:32:35 GMT
content-type: application/json; charset=utf-8
content-length: 253
x-powered-by: Poor WSGI for Python
strict-transport-security: max-age=15724800; includeSubDomains
{"id": 16262, "name": "Pixel 6", "config": {"name": "Pixel 6", "trigger_scheme": "TEN_SEC"}, "sort_order": 1, "token": "qJ6yPMKEK32vrrj8EjU1", "origin": "WEB", "registered": true, "team_id": XXXX, "printer_uuid": "XXXXXXX"}
<-- END HTTP (253-byte body)
But later, when I repeat the exactly the same request, I get 403 and
{"message": "Fingerprint is not valid", "code": "FORBIDDEN_INVALID_FINGERPRINT"}
So, what's wrong with my fingerprint?! Your documentation just states it should be at least 16 characters long. Do you have any more (undocumented) assumptions about that string?
Best Answer by Tojik:
Hi, the fingerprint lengthe is limited to 64 characters. We will update the docs. Sorry
Ce sujet a été modifié il y a 3 years 2 fois par Pitel
Publié : 21/09/2023 9:42 am
Tojik
(@tojik)
Membre Moderator
RE: PrusaConnect Camera API issue with fingerprint
Publié : 21/09/2023 10:12 am
Pitel
(@pitel)
Another issue I found: there is some file size limit for images. And when it's exceeded, you get Nginx's HTML error page instead of JSON error from the webapp. Which is understandable, but would be nice know the limit berforehand, so I could prevent the upload and automaticaly lower the JPEG quality or resolution next time. Or maybe increase it? The full-quality pictures from my Pixel phone are quite large (5-10 MB).
Publié : 23/09/2023 12:13 pm
_KaszpiR_
(@_kaszpir_)
AFAIR default nginx config allows 1MB file uploads, but you could try uploading different file sizes to detect it yourself, I guess it maybe around 8MB?
Publié : 23/09/2023 12:56 pm
Tojik
(@tojik)
Membre Moderator
Yea, would be nice knowing there is a limit before releasing PrusaLink 😅
i tested 4k and it seemed fine. Did not have a camera that Wleould hit the limit, so I assumed it's not a problem
Publié : 02/10/2023 9:13 am
volkersfreunde
(@volkersfreunde)
Membre
I started to collect and would improve the OPEN API spec at https://github.com/falkorichter/prusa-connect-api.
What is the fingerprint - can´t find the answer here... https://github.com/falkorichter/prusa-connect-api/issues/2 is my "issue"
Publié : 03/10/2023 8:35 pm
volkersfreunde
(@volkersfreunde)
Membre
On the file size limit: https://github.com/falkorichter/prusa-connect-api/issues/3 4k seems not to be the size limit...
Publié : 03/10/2023 8:42 pm
Tojik
(@tojik)
Membre Moderator
Should be 8MB. Will update the doc hopefully. Stuff is just on fire lately
Publié : 03/10/2023 9:14 pm
volkersfreunde
(@volkersfreunde)
Membre
I wil update the fork of the file on that repo...
Publié : 05/10/2023 6:55 pm
